Canon Original Battery Charger for BP-511 and BP-512 Battery
S
Steve
Guest
Canon Original Battery Charger for BP-511 and BP-512 Battery - Model CB-5L – SPECIAL
For anyone that has a non UK version of the 300D, 350D, 10D, 20D or any of the Canon compacts that take BP511/512 batteries like the G2/G3 or G6 this is an absolute must.
Down from £39.99 to only £17.99 at 7Dayshop
LINKY
The Canon original battery charger that came with my Rebel (usa model) was fine for use in the UK.
good spot there m8,
but as mentioned, the US chargers will work fine , this is because the voltage range on them works from 100V to 250V , and will work in almost any country as long as you have the adapter lead with the two pin plug ( charger end ) on the lead , this same lead can be bought anywhere in the uk for no more than 2 or 3 quid if needed , polarity doesnt matter as its all AC voltage,
or a plugtop adapter will work fine to convert from US to UK plugs
hope this helps
MyPix
PS.............the Nikon chargers use the same 2 pin plug and voltage ranges, and can be used anywhere just like the Canon chargers
