Hi,
I have recently bought a Sigma 105mm DG OS HSM Macro for my wife to use with her Canon 760d. I also bought a Neewer TTL ring flash.
Using Aperture priority mode, without the flash fitted, I have the following:
1/8th speed
F9.0
ISO 800
(Settings are a bit random as I am experimenting indoors)
So I fit the ring flash, ensuring that the camera external flash is set to E-TTL in the menu and TTL on the flash. Half press the shutter and the shutter speed remains the same! I would expect it to be faster with the flash?! I just get blown out images.
So I tried removing the external flash and using the pop-up flash. Half press and again the settings remain the same!
Am I missing something obvious? Do I have a problem with the Sigma lens?
Apologies if I have missed out some info but If someone has any ideas I can answer their questions.
Really hope someone has an idea.
1/8th speed
F9.0
ISO 800
