- Gareth
Hi guys, I hope you can help.
I have the Irix 15mm and all is well, but!
When using the correct Irix filter adaptor and using 100mm square filters, there is a small gap above and below the filter as the lens optics are slightly larger than the filter. This means that when using a 100mm x 100mm ND1000, I get light leaks and a halo on the image.
So I contacted Irix who in their defense emailed me back within minutes saying I needed 2 items to fix the issue:
The foam gaskets were out of stock, but the square filter protector set IFHP-100-PS1 that are the actual bits that make the filter 'bigger' and block the light getting in were in stock so I went ahead to order them.
The postage originally was €3 and the parts were €7 but when I said I was in the UK, the postage shot up to €50!
I did email back and question the postage cost and was told that it was the cheapest postage they do to the UK but not to worry as if I bought more then the postage wouldn't change!
I've started looking for alternatives as there isn't a UK stockist for this item but all alternatives protect the complete perimeter of the filter which is no good as I just need 2 side protection 'light blocking' sides so the filter still fits into the holder.
Any help or tips would be gratefully appreciated.
Irix Edge 100mm Filter Foam Gasket IFHG-100 | Official Irix brand store
Irix Edge 100x100mm Foam is dedicated for full ND filters with 100x100mm diameter. It seals the filter-holder connection, which is particularly important for long exposure photography.
store.irixlens.com
Irix Edge Square Filter Protector Set IFHP-100-PS1 | Official Irix brand store
Filter Protector Set is designed for protecting the filter from any accidental impacts or damage.
store.irixlens.com
