So in that scenario would the EV be doing any regen at all, i.e. putting any energy back into the battery or as the accelerator is feathered/engaged would the EV not be using energy to go down hill where the ICE would be using no fuel.
Or is the regen braking clever enough to realize what is going on and manage to regen some power?
The above is a serious question as I don't know too much detail regarding regen braking. I used to race Electric RC cars where 'lifting off' a little was effectively braking as it lowered the speed of the motor, it was easy to slide the RC cars under 'braking' via the motor speed alone! The drive of the RC cars was connected to the motor on a permanent basis via belt and driveshafts and all wheel drive (could change the diffs to change off power characteristics but that's completely off topic
If your throttle is held at a position where there is zero power going in or out of the motor. In some cars, this behaviour is configurable via infotainment or flappy paddle (lift off = no regen). It is akin to coasting in neutral gear. You don't get regenerative braking and motor has very little internal resistance to slow you down. No energy is consumed or captured.
In ICE, you will have to coast to achieve similar effect. But not having the wheels drive the engine burns fuel, the engine is effectively idling. Having the engine drive the wheel doesn't burn fuel, but it will slow you down quicker than not energised electric drivetrain.
EV drivetrain actually very simple. You put energy into the motor to speed up. You capture that energy from the motor to slow down. (there will always be conversion losses, no energy conversion is 100% efficient) Zero energy flow and your car will coast according to Newton's laws.
RC car probably have a larger motor power to weight ratio. So the speed is more dictated by motor speed than vehicle momentum. There is also possibility that the RC controller directly controls the motor speed, rather than EV throttle pedal where it controls the input energy to simulate ICE car "gas" pedal.
You are missing the point. Take your foot off the pedal. An ice vehicle engine brakes and the EV starts to Regan braking. If as our friend has assured us, Regan braking in his leaf is like dropping 2-3 gears the EV will slow a lot quicker and in a shorter distance. You will then have to start feathering the throttle to smoothly retain the speed than you would with an ICE engine braking.
No, YOU are missing the point at the start of this post. But finally gets it near the end, still decides to keep arguing though. Everything is configurable in an EV.
You can choose to feather the throttle pedal to drive, effectively drive with one pedal. The brake pedal is only used in an emergency.
stupar mentioned E-pedal is a Nissan marketing name. But it does slightly more thing than standard regenerative braking. When you arrive at complete stop, E-pedal holds the car using frictional brakes like auto-hold until you press the accelerator pedal. At low speed, other EV may apply torque to wheels to mimic automatic gearbox, some EV may roll on an incline because motor is not energised to counter gravity. This auto-hold on stop feature of E-pedal helps you to do more stop-start driving with a single pedal.
