- Terry
That's a hell of a crop.
Are you sure you're not expecting too much at ISO5000?
looks typical to be honest, massive crop at high ISO plus 1/1000s @f5.6Meant to say too big
Not through window
Handheld
IS is on
I'm beginning to think there's something wrong with the camera body. Just my luck.
Photo before denoise. I have altered the colour of the image above, after I denoised it
It does appear that I should be filling the frame as what @LongLensPhotography said previously. But this thrush was behind a fence, and it wasn't standing still for a long period of time.That's a hell of a crop.
I thought this camera could handle such large crops, but obviously it doesn't.
I'm just processing some photos I took this afternoon. I'll upload them when I'm done.
Field craft is freeI'll have to change the way I do things when editing phtoos now.
For wildlife, it sounds like I either have to buy a longer lens, 100-500 or 200-800, or the cheapest option, a teleconverter.
as suggested above by @Gav. working on getting physically closer to your subject is always going to get your the best results.I'll have to change the way I do things when editing phtoos now.
I'm not primarily a wildlife photographer. I only do it now and then.To be honest you'd be better off with a Micro 4/3 I think.
Take a look at some of the bird shots Jeff manages (@the black fox)
looks fine to me, your focussing might be a bit off though
I think it is important to let go of the idea that you need to shoot every single avian within the range in any circumstances. I would rather make 1 really really good image per week or even a month than 100 OK ones. That includes a combination of criteria like subject, interest, filling the frame, getting good light, etc.But this thrush was behind a fence, and it wasn't standing still for a long period of time.
Canon RF doesn't have any affordable lenses I would consider usable in UK weather. I barely get by with a 200-600mm at f6.3 at long end and even then its a massive stretch.
The f7.1, f8, f9 and f11 aperture tele-lens might be super in Australia or Africa or shooting polar bears in August in the arctic but it just doesn't cut it even with latest greatest FF sensors in the UK.
IMO, these lenses are clearly made for a different country or population than those that shoot wildlife in the UK (half which are small/tiny birds sat in tree/bushes with overcast sky!).
Let the camera do the job with animal AF. That's pretty much the whole point of buying the Rs.I focus three thirds into the scene. They were on auto focus.
Yep I know.Let the camera do the job with animal AF. That's pretty much the whole point of buying the Rs.
I presumed he was talking about the landscape images - also assumed he meant two thirds not three thirdsLet the camera do the job with animal AF. That's pretty much the whole point of buying the Rs.
Correct, and yes I meant two thirdsI presumed he was talking about the landscape images - also assumed he meant two thirds not three thirds
+1. I'd focus on fieldcraft and composition for now. If you find you love birding and have the funds then think about a big prime.The best options for Canon come pre-loved in EF mount.
A good budget option is 100-400 II which OP has
Nice photos on your instagram. Are they with the R5?A dark background produces more noise than a brighter background.
The noise in your samples looks pretty much the same as my R5.
past 2 years, yes.Nice photos on your instagram. Are they with the R5?
Sort of. I need better light. Haven't used camera much since I got it. I'll be using it more next month.Did you get this issue sorted?
I was told this about iso and noise
Nope, I am not mistaking you for someone else, I am simply trying to help out a bit. I hope your testing proves fruitfulPrevious to this reply, you haven't replied to my thread, You must be mistaking me with somebody else.
I'll know about the camera next month when I use it more
This is technically incorrect. The ISO setting can't create "more light". It's just increasing the sensor's sensitivity to light.I was told this about iso and noise: All iso does is give you 'more light'.
It's a tough ask to get the same aperture and shutter speed for a different ISO if the light source is constant.Both not shot with the same exposure. Can't do a like for like comparison unless you have same exposure i.e. aperture and shutter speed.
Unfortunately adjusting the ISO does not increase the sensors sensitivity to light.This is technically incorrect. The ISO setting can't create "more light". It's just increasing the sensor's sensitivity to light.
Much like any form of amplification, there are levels of quality and efficiency that vary sensor to sensor but the key is that the quality of the signal you're amplifying is hugely important.
If you bump ISO in a well lit scene, your results are going to be cleaner than if you bump ISO to the same level in near darkness and raise shadows.
The only way to give your sensor more light is to use a wider aperture, a slower shutter speed or manually add additional light to your scene.
Would you be able to form a better explanation of what it's doing for us then?Unfortunately adjusting the ISO does not increase the sensors sensitivity to light.
Yes, sorry, I can see where you were going though.Would you be able to form a better explanation of what it's doing for us then?
I mean technically it's just amplifying what's hitting the sensor but I was looking for an easily understandable catch all to explain the concept. Perhaps I chose poorly.
I think the 'gain knob' analogy is the best analogy for sure but it only works with people who've attempted to play guitar badly at some point. Like me.As far as I know ISO changes the gain of the amplifiers behind the photodetectors. Higher ISO = higher gain thus increasing the noise.
What you are seeing looks perfectly normal to me.Only had this camera since yesterday evening and this is the first time trying it out. I've come from the 5D MKIV which is 30MP.
Processed and cropped.
Tripod and 2 sec timer.
These are RAW and not processed.
LR and no noise reduction, except for the right photo of the blue tit.
Oops. I read the beginning incorrectly, I apologise.Nope, I am not mistaking you for someone else, I am simply trying to help out a bit. I hope your testing proves fruitful
